RE: big problem
That's a tough one. first off, make sure the ESC isn't too close to the RX. It sounds like you are getting rf interferance from the motor, but i could be wrong. Try another RX on the bench if you can, see if that makes it go away. Another thing could be a bad crystal. Vibrations from the motor might be causing it to go haywire. Do you have full control before you throttle up??
