Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
big problem
Old 11-09-2006 | 07:36 PM
sokrdz's Avatar
Default big problem
hi everyone,
i just finished building an gws estarter with a bp12 brushless motor and a castle creations t-18 esc.
the problem is, is whenever i turn on the transmitter and hook up the battery and start to throttle the motor everything stops and goes out of control.
i cant control anything and everything isjittering.
i cant seem to find the problem.
please help
thanks
Old 11-09-2006 | 07:46 PM
Matt Kirsch's Avatar
My Feedback: (21)
Default RE: big problem
It sounds like maybe you have the connection from the ESC to the receiver plugged in backwards.
Also make sure that you've got the right receiver crystal, and the right type of receiver for your transmitter (JR/Airtronics requires a different receiver from Futaba/Hitec).
If you can confirm that all your connections are correct, then the next step is to start eliminating pieces one at a time by replacing them until things work. First, replace the ESC and motor with a 4-cell receiver pack to verify proper operation of the receiver and servos. Replace the ESC if the servos work properly with the receiver pack.
Old 11-09-2006 | 07:48 PM
My Feedback: (9)
That's a tough one. first off, make sure the ESC isn't too close to the RX. It sounds like you are getting rf interferance from the motor, but i could be wrong. Try another RX on the bench if you can, see if that makes it go away. Another thing could be a bad crystal. Vibrations from the motor might be causing it to go haywire. Do you have full control before you throttle up??
Old 11-09-2006 | 10:18 PM
sokrdz's Avatar
well when i turn everything on and plug in the battery sometimes i have control then i throttle up and it goes haywire and sometimes it does nothing then starts going haywire not even when i throttle up.
Old 11-10-2006 | 12:52 PM
Fliprob17's Avatar
Have you run thru the setup on the ESC again to verify that everything is programmed/setup correctly? Also, make sure your antenna wire is routed properly and away from items that may cause interference. And make sure you are doing these tests with the antenna on the TX up, sometimes having it down and testing works, but sometimes everything twitches, simply raising the antenna on the TX fixes it occaisionally.
Old 11-10-2006 | 04:29 PM
sokrdz's Avatar
well i tried to program the esc but nothing happended it would just keep beeping wich meant it was ready to be programed.
Old 11-10-2006 | 05:30 PM
Raz
As mentioned you may have a bad rec. or esc. Transmitter works with other project? may be low on batt. if you eliminated these and the problem still there, wrap the rec. in aluminum foil it may help!
EL Raz
Old 11-11-2006 | 10:01 AM
sokrdz's Avatar
i think i found the problem
it was a bad reciever. so i am going to return it for a new one.
thanks for your help
