RCU Forums - View Single Post - SR Batteries Eindecker Questions...
Old 11-09-2006 | 11:31 PM
feep's Avatar
feep
Default RE: SR Batteries Eindecker Questions...
Hey Cam, Good to hear from you. The words are Hier aufassen forward most and the last 2 points say Hier unterstuen with 2 dots above the "u" after the "t" I'll see about getting a font. The Oberusel is actually a Photo of a Le Rhone which Don ( Abufletcher) supplied on another thread. I doctored it up a bit and mounted it on a piece card board. I doctored the pic by removing the red spark plug cover.
Nickbee, I didn't use blocks because my wings were already built. I drilled holes in the blocks and wired them to the spars and than wrapped the blocks to the ribs with coverite. The drilled block idea is so much more simple provided you incorporate them as you build the wing. However you do it, I can testify that it will save you head aches. I have made a few hard landings and the wires ended up behind the wheels with the aircraft nosed over and the rigging remains intact.
