RCU Forums - View Single Post - upgrading to 9ch super
Old 11-11-2006 | 01:41 PM
robflyer82
Default RE: upgrading to 9ch super
I recently did the same upgrade. I was able to transfer everything fine, including my trims. Just make sure you doule check everything after the transfer like you were going to maiden the plane again (after all, its a maiden flight for your transmitter) and you should be good to go. The hard part is getting enough planes and helis to fill up your memory [8D].
Rob
