RE: Robbe Dusseldorf instruction book
Thanks for the info JSGill. How did you mount the bilge pump to pick uo the water? Did you modify the housing, or have a through hull mount?. On my tugs I usually use a 12 v replacement windshield washer pump. The stream I get is usually only 10 ft at best.
Pacmetalman
