RE: Servo travel
Hans
I will assuse with a hs55 as a retract servo this is a park flyer? The optic 6 should have channel mixing or programable mixes. Set channel 5 as master and channel 6 as slave should work ok. If you need more servo travel than the arm will give extend the arm with some thin plywood. I hope this makes sense.
