RE: Pusher Prop Question
Another big ditto. I have seen this happen all too many times.
Look at the prop.
Determine which side is the front and which is the rear (You used to be able to say that the side with the lettering was the front, but some companies are now printing the rear side)
Once you have determined which side is the front, install the prop with that side facing the engine (Which is opposite to the way you would normally mount it)
