RE: Briggs 4 stroke trimmer engine!!!
That tells you all the mess happened in the crankcase. Check and see if the bearing cages are intact. Are the broken pieces aluminum or steel or both ? Do they have machined or cast edges? Are there any broken pieces from the skirt of the piston.
