RCU Forums - View Single Post - nemesis stalling problem
Old 11-16-2006 | 03:31 AM
notch
Default RE: nemesis stalling problem
I sounds like a clutch issue...
although you vented bell could be binding......
check your engine mount screws!!!
the mesh not only needs to be set correctly but the motor has to be pointing straight
the easiest was to get a killer mesh is to disconnect the pipe during engine/mesh set-up
