RE: HELP!!!!!!
i dont know how much experience you have you are going to need to adjust your throttle arm throw, there should be a little spring or peice of fuel tubing that compresses when you apply the brake, whick in turn closes you throttle too much , you could either adjust the throttle stop screw to solve the issue of it turning off or loosen the spring/fuel tubing compression hopew that helps
