RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
HELP!!!!!!
Old 11-16-2006 | 07:47 AM
Default HELP!!!!!!
im having a problem my car is running wierd it idles high and when i hit the brake it stalls can anyone help me?
Old 11-16-2006 | 08:19 AM
MetallicaJunkie's Avatar
Default RE: HELP!!!!!!
i dont know how much experience you have you are going to need to adjust your throttle arm throw, there should be a little spring or peice of fuel tubing that compresses when you apply the brake, whick in turn closes you throttle too much , you could either adjust the throttle stop screw to solve the issue of it turning off or loosen the spring/fuel tubing compression hopew that helps
Old 11-16-2006 | 09:09 AM
nickrummy's Avatar
To me it sounds like the throttle trim on the radio isn't set right and your idle stop screw isn't set right either.
First thing I would try is reducing the throttle trim on the radio which should close the carb a little bit. Do this until you get a good idle. After that is set adjust the idlo stop screw until it start bringing up the idle. As soon as it starts bringing up the idle back it off a bit. Now hit the brake and make sure the motor keeps running. The idle stop screw keeps the carb from closing when you hit the brake. If it isn't adjusted properly, when you hit the brake you will close the carb, shutting the engine off.
If you can't get the proper idle by adjusting the throttle trim on the radio you might have to adjust your throttle link length.
Old 11-16-2006 | 11:45 AM
Banned
Sound to me like your throttle trim is set to high and your idle is set to low. Screw the idle screw in, watch the carb and make sur eit doesn't close shut when you hit the brakes.
Old 11-16-2006 | 10:51 PM
i think it might also have something to do w/my clutch shoe i put a little oil on it and it idled ok but i still cant get the other needle settings quite right i could really use some advice...
Old 11-17-2006 | 10:44 PM
well i took my clutch apart and my spring came off so i put it back on and hopefully it will make a difference...try it ag tommorow.
Old 11-18-2006 | 04:49 AM
no , idling doesnt have anything to do with you clutch shoe... try what was recommended above
Old 11-18-2006 | 04:56 AM
Woodmandan2's Avatar
your glow plug could also be damaged. When i bent the spring in mine it would idle really high but when i would hit the breaks it would quit. Now with the new Plug im good to go!
Dan
Old 11-20-2006 | 09:16 AM
has any one had a problem w/the fly wheel? one of the pins that hold the clutch came off of my tsunami just wondering if anyone has had a simialar problem?
