RCU Forums - View Single Post - Monokote Technique
Old 11-16-2006 | 09:11 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Monokote Technique
Cover the wing with yellow so that it is a finished covering job (I.E. shrunk and ready to fly)
Next I would draw (With a fine-tip felt marker) where the red is going to be (You can use the red pieces as templates).
Then I would just hand cut the openings with a #11 blade - Leave about 1/2" For the next layer to stick to.
If you look at the videos I did, I show the technique of sticking one covering onto another over open framework in Video #4 (Right after the "Benny Hill" music) where I lay the red tip over the white.
