RE: Hangar 9 Twist 3D
Here's a question for all. . .
what do you do with the extra antenna wire extending out the bottom tube? On the 4-stroke, I ran it along the bottom towards the wing, then made a u-turn with the balance of the wire. I covered it with some covering to protect it and keep it from getting snagged.
Today I robbed my other receiver out of the trainer and have installed it in the 2-stroke and have done a function check and set the EXP and dual rates, as well as engine cutoff and subtrims so controls are "square" to each other. I'm a little anxious on just where CG needs to be. Past posts place it around 5" behind leading edge with emply tank. Am I getting it right?
My plans are to bring it out to the feild saturday for someone to do a shakedown with me on the cord.
Just talking about it makes me so nervous I wanna go pee[sm=drowning.gif] . . . . . . .
Jeff
