RE: Composite-ARF Integral
Chris,
The rudder is pinned with a streel rod (1.5mm or so) that just slides in a tube in the rudder and through the phenolic horns you see there on the rudder post. Bend a right angle in the rod and tape it on the bottom of the rudder so it doesn't go anywhere and you're set.
Jason
