Motor trouble with Parkzone esc/receiver
I have recently purchased a complete esc/receiver/servo/transmitter set up out of a flying Parkzone Focke-Wulf 190 and am having some motor problems. The motor will not run until you advance the throttle half way and then slightly past half way the engine stops running. I am using a 8.4v 730 mah Ni-Mh battery, a GWS EPS-350c motor with a 3.75:1 drive, 10 x 6.5 prop. The servos function properly and I have the jumpers set for a Ni-Mh battery. I have only bench tested this combo and have only been running the motor for a max of about 10 seconds at a time. I hooked the battery straight to the motor and it runs fine. This combo, if it ever works, will go into a scratch built park flyer weighing under a pound. I did serch the forums before posting and came up empty. Any thoughs? Thanks
