RE: Midwest Citabria Build Thread
If you diecied to use the pvc plastic parts the best glue that I have found is all pupose pvc cement used to glue pipe together. It also works good for putting on the fiberglass reienfocements inside the cowl and pants.
I ussually go with aftermarket fiberglass parts but decieded that I would give the pvc plastic a try. It tooks some work but it came out pretty good.
