RCU Forums - View Single Post - Homelite 45 Q's
Old 11-18-2006 | 07:08 PM
Mike@Accurate
Default RE: Homelite 45 Q's
Progress today.
First cut. I tried to get as close to the sleeve as I could (into it a little). Still didn't come off.
So I die ground it a good ways in. Still didn't come off.
So I put it in the mill and hit it with a 7/16" end mill. I was almost all the way through before it was free. No need to cut any more.
It is OFF!
I took the bottom of the case to the band saw and cut off the boss.
And belt sanded it.
Looks good.
I milled off the studs. After removing the material around them, they fell out.
And I milled off the fins.
Ready for mounts and a prop hub.
Almost ready to start the hull. Thanks, MIKE
