We use the same nylon bolts to hold the wings on alot bigger planes than this one. No problems at all.
Smokey
ORIGINAL: n1toga
HI guys,
just a question about the with mounting. Never seen a 2 piece wing setup before..and the instructions are limited to a couple of lines and a photograph....so..do you glue the spar-tube to one of the wing halves? Looks awefully flimsy to be held by only 2 nylon bolts per wing.[
