RE: help a newbie
The only drawback to the suspension is the plastic swing arms. The point where they screw to the hull has a tendancy to split. other than that and a gear tooth issue i havnt had any troubles with the kit. The suspension uses torsion bars. Unlike the other kits in the tamiya line t actually uses a round bar instead of a flat spring bar.
