Suggestion for Rudder/Elevator Pushrod
I'm building a P-51 from scratch. What has y'all had good luck with for controlling the aileron and elevator? I have seen some use threaded music wire with guides every 12" or so. I've seen some that use the commercial flex push rods that have the outer sheath and inner push rod that is plastic. What do you prefer? My servos are in the wing and the tail is about 24" back. Thanks, Chris
