RE: Need prop suggestions...
OK, I can see the brown prop is an octura, and I can see the numbers 435, but can't see the preceeding digit but looking at the ones that are available now, it must be a 1435.
So with how the boat acted (described above), what would you guys suggest as some plastic props to try?? If I can figure out a good prop to use when testing with plastic ones, I will probably drop the money on the equivalent metal one...
Sean
