RCU Forums - View Single Post - MVVS Isolation Mount
Old 11-20-2006 | 04:47 AM
BaldEagel's Avatar
BaldEagel
Default RE: MVVS Isolation Mount
Pe
Yes you are quite correct, unfortunatly if you fit the cross beams vertically in relation to the engine you end up with the members in front of the exhast which could be a problem if the bend off the stub needs to be tight to accomadate a narrow cowl, should not be a problem on most installations with standard manifolds however.
Mike
