RE: Two Cycle Oil for Air Cooled Engines
Unless you're running the engine for hours at a time, mixing the Belray at 65-1 is probably a good idea. It's a great oil and manages to lower the running temps a little. If you're using a denser oil mix then re-working the needles would be a good idea to get things back to peak again.
