RCU Forums - View Single Post - Nitro models pusher Bobcat?
Old 11-21-2006 | 01:59 PM
  #562
knighttwister
My Feedback: (59)
Default RE: Nitro models pusher Bobcat?
ORIGINAL: CAPMDON
I noticed on this page NONY also makes mention of rotating the carbs but it will only work if the front hub w/carb is bolted to the crankcase.
All the ducted fan engines have a bolted carb assembly. Simply take out the bolts and rotate the entire assembly tighten it down and your
ready to go.
when you rotate it, from looking at the prop stud from the front, which way do you rotate it? thanks
