RCU Forums - View Single Post - center of gravity
Old 11-22-2006 | 07:39 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: center of gravity
Here is my rule of thumb for finding CG:
IF I were given a plane and had no idea where it should balance, I would balance it on the spar, but make sure it sits slightly nose-down - Because a nose heavy airplane will be sluggish, but it will still fly - A tail-heavy plane will be uncontrollable.
Then fly it.
Once airborne, First thing is to see how it handles. If it handles ok, I'll try a spin. If it won't spin, that's usually a good indication that it is nose-heavy.
Next comes the landing. If it won't slow down, that's another indication that it is nose-heavy
So if I have determined that it is nose-heavy, I will move the CG back in small increments (1/8 - 1/4" at a time depending on how bad it was the first time) until it flies the way I want it to.
