RE: Replacing Motor
The Stock Motor uses a Standard shaft. Now if you happen to find a motor for cheap that has a pilot shaft you can use it you just need to find a clutch bell, clutch pads and new flywheel for it. OR you can jsut cut off the pilot shaft part and use your standard flywheel nut with the clutch bell shaft on it from the st-15.
