RCU Forums - View Single Post - center of gravity
Old 11-23-2006 | 10:18 AM
drone pilot
Default RE: center of gravity
Mike, Finding and setting the CG are the same thing. Once the CG point is found ( set) then you balance the plane to that point as previous posted. If you look in the manual towards the back there should be a page that mentions the control surface movements and the balance point (CG). If you still have problems you would be best advised to go to a hobby shop or a R/C Club and get some personal help, then you can see and perhaps better understand. Good Luck
