RE: Need Help Re&Re HL Pershing Metal Sprockets
You have to sand down the shafts for the sprockets to fit, or open up the sprockets a little. Your choice, the shaft is easier IMO. As for the bearings in the gear box, you have to remove the gearbox from the tank and then unscrew the halves to get everything apart for re-fitting. It's all screwed together.
