RCU Forums - View Single Post - Throttle linkage hitting body
Old 11-24-2006 | 04:37 PM
Rs43EVOman's Avatar
Rs43EVOman
Default RE: Throttle linkage hitting body
ORIGINAL: AC1
I have the same problem with a 777 when I go full brake. I checked the linkage in every way and I'm getting perfect braking, but it still taps the body enough to create servo bind at the end of the brake EPA (those Pro-Line bodies are pretty tight).
I did the hole trick and its now fine, but I still wonder why I don't see these holes on pro buggies (like Pavidis using the same Pro-line body) and we have to do them...
Becuase as ive been trying to say. Obviosuly the linkage isnt supposed to be hitting the body, so instead of avoiding the problem, and cutting a hole in the body actually fix the problem.
