RE: Cant uscrew motor mount screw- HELP ME, Help
You may have to get nasty if it does not come out..... unbolt the mount from the engine to get the engine out and out of the way. Cut the rubber mount as close to the stringer as possible and remove the cut mount. You will then have to break out your dremmel tool with the cutting attachment and carefully cut and grind the rest of the mount to cut it away from the bolt.
