RE: F27 STRYKER - Way Past the Limits - Part 5 - Step in to the Dark Side...
Buggygovroom,
This is an edit:
I see my original post will live forever.
Seriously, I was looking at the pics that you had sent me, and I see that the battery is all the way forward. Starting from the front edge of the hatch and then going back. It looks like the cooling air from the vents is going to be behind the battery. I have no doubt that you will be checking the temp of the battery.
Question: If the battery ends up getting a little too hot, do you have any plans as far as how to cool it? Will you be cutting 2 more vent holes, or 1 vent hole on the bottom with your famous scoop, or 1 hole through the center of the nose...? Any ideas ahead of time?
Gryphon
