RCU Forums - View Single Post - GP Cap 232
Thread: GP Cap 232
Old 11-25-2006 | 07:59 AM
  #231
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: GP Cap 232
ORIGINAL: AussiePilot
yuh i didnt open it up either i think i will just leave it fr now, if i feel like it needs it ill do it after the maiden....
just curious how did u adjust the throws on this cap.??? i.e what did u use, im using a measuring tape not sure what else will work...
Also how did ur plane balance on ur cg machine.???
well my props are on there way from tower hobbies should be here in a few weeks.... cant wait...
I used a tape measure and measured it at the widest part of each surface. I'm basically beyond what the book tells you as I have max throws on everything. When I balanced mine I marked the top of the wing on each side, flipped the plane over and put my fingers on each mark and lifted. I used to use the CG machine but for larger planes it does not work well
