RE: F27 STRYKER - Way Past the Limits - Part 5 - Step in to the Dark Side...
Buggy: 700 Watts in that little Hawk - wow no wonder its a rocket!
What motor, prop and number of cells where you using? Same set-up as on the 120mph Stryker but on 5S?
I ordered one of those Jeti controllers and if I did not have a watt meter I would have got the SPIN version ESC which logs everything a wattmeter does during flight but it is a fair bit heavier.
