RCU Forums - View Single Post - Gap Filler
Thread: Gap Filler
Old 11-26-2006 | 09:36 AM
SoCalSal
My Feedback: (16)
Default RE: Gap Filler
[quote]ORIGINAL: Chip_Mull
You can also use a two part epoxy filler called "Superfil". It's an epoxy base and doesn't shrink like Bondo or polyester leaving a tell tale ring. It's lighter than any filler you have used and sands well. It also has enough body to stand on its own.
Superfil is avialable at: http://www.stits.com/store/msc.html
It was designed for the full scale guys building EZs and other composite aircraft using 6 oz cloth needing a good light weight filler.
[/quote
This stuff really works well. I used it on my 33% Waco and it is just the greatest stuff to work with. Try it. You will find many uses for it.
