Gap Filler
My Feedback: (19)
TX
Anyone know what I can use to fill a rather large gap between the shroud and cowl on my P51.I need somthing that I can use like a putty
that will harden like epoxy.
Many Thanks
Pappy
Many Thanks
Pappy
My Feedback: (33)
You can use a polyester body filler from the auto shop. It fills and can be readily sanded for a great fill. I use it for farings and other places where I need such a thing. Hardens like epoxy/Bondo. If you want to make it really tough, add fiberglass shavings/powder to it.
My Feedback: (118)
TX
Another option is to use cotton flock and epoxy. Easy to work & shape and is quite strong without too much weight. I get my cotton flock from Aircraft Spruce & Speciality, cheap stuff.
Safe Flying!
Safe Flying!
You can also use a two part epoxy filler called "Superfil". It's an epoxy base and doesn't shrink like Bondo or polyester leaving a tell tale ring. It's lighter than any filler you have used and sands well. It also has enough body to stand on its own.
Superfil is avialable at: http://www.stits.com/store/msc.html
It was designed for the full scale guys building EZs and other composite aircraft using 6 oz cloth needing a good light weight filler.
My Feedback: (16)
CA
[quote]ORIGINAL: Chip_Mull
[/quote
This stuff really works well. I used it on my 33% Waco and it is just the greatest stuff to work with. Try it. You will find many uses for it.
[/quote
