Exceptional fuse weight. Jaz will he sell me just the fuse?
Matt
ORIGINAL: JAS
Here are the weights of most everything. Thank you Vince for the chart. We are debating on making the canopy "solid" instead of a clear canopy. It would probably save close to 3ozs. I am missing a rudder/tank/Rx and Batt tray along with the couple little things from below for a final weight. Then I'm sure there are some odds and ends to, but it looks like about 10-10.25lbs. If anyone can think of something to add to the weight list, let me know. And the car works, without the box, just fine Derek. I remove 1 stab half and it slides right up the middle. Oh yea, the * are all weighed as one.
Fuselage 27 (only missing rudder servo tray/tank/batt/Rx trays. Gear plate, rear formers, rudder post and hinges, wings/stabs mounted and aligned, firewall installed)
Belly Pan 2.2
Canopy 4.5
Hatch 2.4
Right Stab 4.1
Left Stab 4.2
Rudder 2.1
Right Wing 14
Left Wing 14
9151 servo x2 3.6
9351 servo 2.2
3002 servo x2 2.6
5102 servo 0.7
Servo screws
200mm ext x4 0.4
400mm ext
1000mm ext x2 1
Futaba 149Rx 1.2
Futaba switch 0.4
Shulman Aviation 6V Reg 0.5
Thunder Power 2-cell 910 battery 1.7
Nose ring 0.1
Tank 24oz Du-Bro 3.1
Fuel line
Fuel dots
Fuel T's
Tru-Turn Jam nut*
Hyde Mount CR MKII*
Engine OS200 EFI* 41 (other * marked objects are included in this weight)
Header*
Canister*
APC 17x13 4.2
Tru-Turn 3 1/4" Spinner Solid BP 2.9
Wing Tube 3.9
Stab Tube 0.4
Main wheels 0.9
Landing Gear 3.2
Wheel Pants 1
Tail Wheel
Total 149.50 ozs
Total lbs 9.34
