RCU Forums - View Single Post - Which transmitter is best?
Old 11-27-2006 | 12:41 PM
Jeff_edge540
Default RE: Which transmitter is best?
Thanks rmenke.
BTW: the 'crow' or speed brake is something I have a problem with on the 8UAP. I set it up fine - the problem is it only allows the B switch assignment for crow. This is my duel-rates switch for all other aircraft.
Other issues I have with the 8UAP is flaps... I can't set the dial for 0 flaps all the way to the left. It must be straight up. This makes it hard to know when you are at 0 during flight without looking at it. Also, I cannot mix elevator with flaps, i.e. when i dial in 20% flap - I want 5% elevator. It only allows you to mix flaps with elevator, i.e. when you give up elevator it mixes in flaps. This is for tight loops and not for mixing pitch coupling out with flaps down.
Question regarding JR.. Can I still use my Futaba PCM receivers with a JR transmitter?
