Sharp LE (is it a myth?)
Hey cool! Great to see you here Cajun!
One of the reason I brought this wing, and this ugly airplane to this forum is because it has blown me away. The plane will do a walking speed 45 degree slow pass and never flinch. I can't stall it. It also does the most solid Sloooooooow inverted passes I've ever been able to do with any airplane. There was a Cadet at the field the first time I brought it out, and I blew it away in slow flight. The plane will toilet bowl almost as good as a pizza box, and negitive G stuff is as solid and almost as responsive as positive G stuff, which is unheard of for a Spad airfoil. The only difference from previous Spads is the 4mm stressed over the spar instead of the double facet, and the wing's chord is 14" instead of the normal 12" for .40 sized planes. If you have a Debby handy, slap one of these wings on it and try it. I have no idea what we did right, but I wouldn't change a thing about this wing!
