RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 11-28-2006 | 05:12 PM
  #66
PeterP
Default RE: Composite-ARF Integral, kinda build thread
Hi Jason and JP (Znline)
I have noticed from pictures posted on the ZNline website (Integral Build) that the model in those photos has CF reinforcing in the nose section while the model Jason is assembling has balsa.
Are there going to be 2 versions of the same model with different material specs. What is the marketing approach. I am aware that ZNLine make a builders version which I assume would be based on their typical material (CFG fuse and Foam/Balsa wings) The pictures on the ZN site are definetely Comp-ARF manufacture if you look at the wings and seam line on the fuse.
Peter[sm=confused.gif]
