RCU Forums - View Single Post - Covering scheme
Old 11-28-2006 | 07:25 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: Covering scheme
Kevin has the right idea.
Go PAST where you need to, then cut right at the part where it is adhered - even if you have to lift it a bit, then iron it back down.
BTW, just from what you described about the covering losing it's elasticity after being heated I'm going to guess that you used MonoKote. Am I right?
