RCU Forums - View Single Post - 27% Cessna 421 Twin Turbo Prop
Old 11-29-2006 | 07:43 AM
  #33
Wren Turbines USA
My Feedback: (39)
Default RE: 27% Cessna 421 Twin Turbo Prop
Rudder assembly underway. I used 7/64" piano wire inside large nyrod...laminated between the balsa sheet leading edge..... for the hinge. The rudder is removable by simply pulling the wire out.
The stand-off posts aeropoxied to the vertical fin are cut from C/F and have a brass tubing epoxied inside the hinge point. This does take some time to set up, but worth it in the long run.
ID:	568680   Click image for larger version
ID:	568681   Click image for larger version
ID:	568682   Click image for larger version
ID:	568683   Click image for larger version
