RCU Forums - View Single Post - Two speed trans
Old 11-29-2006 | 02:27 PM
ehroof
Default RE: Two speed trans
you can adjust it, there is a set screw on the 2 speed shifter, clockwise it shifts later and counter clockwise and it shifts earlier. be careful not to tighten too much and crush the spring inside or loosen too much then the spring falls out with the set screw.
