RE: 4 stroke
Any engine, two or four stroke that uses muffler pressure to the tank can easily be choked by merely holding your finger over the muffler outlet and hand flip the prop a couple of times with the throttle fully opened. Just make sure the glow lighter is not on. If you are not using muffler pressure then just blow into the tank vent line. Easy to force a little fuel into the carb.
