RCU Forums - View Single Post - rcingitions.com G-26 conversion questions
Old 12-01-2006 | 11:29 AM
  #32
karolh
Default RE: rcingitions.com G-26 conversion questions
ORIGINAL: arobatx
Are you using the RC100 as an ignition switch? If so, has anyone else out there done this, or know if there is risk of RF interference since the ignition will be wired to the receiver through this switch?
In reality the switch is plugged into the Rx and spliced into the ignition battery circuit and not the ignition directly. I plan on using one and posed that very same question to the RCATS rep who advised me that it's use would not cause any RF interference. You can check their website at: [email protected] . HTH
Karol
