ORIGINAL: arobatx
Are you using the RC100 as an ignition switch? If so, has anyone else out there done this, or know if there is risk of RF interference since the ignition will be wired to the receiver through this switch?
I am using the RC100 as a transmitter controlled kill switch. It's a relay so there is not a direct connection from the receiver to the ignition.
