RE: Cheap Brushless Setup
outriggers are the fastest hull you can make, (do outrggers have the two small sponsons on the back of the main hull??) and use the least material, so thyre lighter too.....i say go for it....why not get a gearbox though, there not that expensive and because BL's spin at high rps, it will be able to spin a biggers prop at normal rps..i guess
