RCU Forums - View Single Post - Super Skybolt Build
Old 12-03-2006 | 05:19 PM
ChrisMH's Avatar
ChrisMH
Default Super Skybolt Build
Well, I know there have been a couple of other Skybolt build threads lately, but I don't care Here's mine.
Some changes I plan to make (or changes I'm considering):
1. One major change I'm considering is the finish. I'd like to glass and paint instead of covering with film. I like the look of the glass finish so much better, but I've never done it before, so we'll see. I know the Skybolt tends to build heavy, so I'll wait to see how much weight I can remove before making my final decision. The wings would have to be fully sheeted, but that appears to be the only additional material that would have to be added to support the glass. If I can remove some weight in the fuse, it might be feasible. Opinions welcome.
2. I'll be replacing all of the control hardware. It's all 2-56 and I prefer the stiffness of 4-40. I'll also be replacing the control horns with either Robart or DuBro heavy-duty.
3. Pull-pull rudder
4. I'll likely replace the 2-piece firewall with a single piece of 1/4" aircraft ply. I may replace some of the other ply pieces as the quality of some of the wood seems a bit dubious.
5. Fairings on the upper wing mount (maybe)
That's all I can think of for now, but I'm sure I'll find some other stuff.
OK, on the the pics (hopefully they showed up in the right order...but I'm sure you can figure it out if not):
1. The obligatory "before" shot. I was lucky enough to get this kit on eBay along with a Stan's Fiber Tech cowl and wheel pants, and a 2 1/2" aluminum spinner...all for $165. Good deal
2. Closeup of the cowl & pants. These are very nice...much better than the stock ABS.
3 & 4. Lots of parts! Everything's marked & accounted for, so...on to:
5. Fin & rudder framed up.
TBC...
ID:	571187   Click image for larger version
ID:	571188   Click image for larger version
ID:	571189   Click image for larger version
ID:	571190   Click image for larger version
