The CG is on the money. I flew mine on Sunday and was like flying a feather. This is a great aircraft. You should all get rid of that split gear and get Supergear for it. The gear that they make for the CH Double Vision fits great.
www.rcsupergear.com
I punch a hole through the Fuse at the CG Be sure you get some plywood. Using a short piece of PVC pipe, drill two holes through the pipe 6" apart, thats the width of the fuse. bend the ends of some pushrod materal, 4-40 rod, about 1/2" one for each side, and put the other end through the two holes in the PVC and bend those ends as well. put the half inch bends through the two holes you drilled in the fuse. Put the wings on and slids them up agenst the rods so that thay won't come out. Pick the plane up with the PVC handle and thats how I locate the CG on my airplanes
