RCU Forums - View Single Post - Super Skybolt Build
Old 12-05-2006 | 12:03 AM
ChrisMH's Avatar
ChrisMH
Default RE: Super Skybolt Build
Another good night in the shop. Good to be building again
1. Straightening the fin TE and rudder LE.
2. Jig I use to straighten and square edges of control surfaces, sheeting edges to be jointed, etc.
3. I'm using Robart hinge points. I prefer to drill for them when all edges are still square...so I did it before the rudder is tapered.
4-5. The bonus is that I can join the surfaces using 1/8" dowels and sand it as a unit to ensure everything is flush. (Credit to Paul at Airfield Models for this fantastic idea...at least that's where I saw it )
6-8. Tapering the rudder. I don't remember where I saw this idea, but it works great. Taper the first side using 3/16 wire on the LE and 1/8" wire on the TE. Flip it over, leave the 3/16" and replace the 1/8" with 1/16". Results in a nice uniform taper. I know the directions say the TE should end up at about 3/32", but 1/16" is close enough.
9. Fin & Rudder sheeting joined.
10. Stab and Elevator frame up started.
Oh, the blue stuff on the fin/rudder is some of the pics is Evercoat polyester filler. The die-cutting was a bit crunchy in some areas.
TBC...
ID:	571915   Click image for larger version
ID:	571916   Click image for larger version
ID:	571917   Click image for larger version
ID:	571918   Click image for larger version
ID:	571919   Click image for larger version
ID:	571920   Click image for larger version
ID:	571921   Click image for larger version
ID:	571923   Click image for larger version
