RE: Epoxy Mold Making
Here you go, I got the numbers you wanted. The Freeman number for the aluminum surface coat we used to use is 701. Mix ratio is 12.5 to 1 PBW.
What we switched to is made by Adtech, also alumiinum filled and the number is ES-229. Mix ratio is 10 to 1.5
Hope this helps ya.
